Results 1 to 16 of 16
    Mar 2011
    Paris, France
    Hello
    This is a newbie question.
    I taped a conference with a Sony camcorder that saves video as AVCHD. After a couple of hours, Windows Movie Maker finally read the whole file on my Windows7 laptop.
    Since the video was shot a bit wide, I'd like to crop the picture to get rid of the excess space around the speaker.
    Although I've already done this with AviDemux, it seems like Movie Maker doesn't provide this.
    What would you recommend I do? Convert AVCHD to AVI and perform this in AviDemux? Download the trial version of Sony Vegas Movie Studio, provided it can read AVCHD? Other?
    Thank you.
    Mar 2011
    Paris, France
    Ok, thanks.
    BTW, is there something better than Sony's Quick Start Manual that I should read to learn how to perform basic tasks?
    I'm stuck at removing a segment: Neither Edit > Cut nor Edit > Delete actually remove the segment. It just leaves a black, silent segment.
    Thank you.
  4. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Vegas doesn't use that type of terminology, i.e. "segment, cut, edit".
    You can crop in the "Crop Dialog Box".
    You can resize in the "Track Motion Dialog Box".
    Mar 2011
    Paris, France
    Thanks for the tip. Even after Googling and reading Vegas Movie Studio Quick Start Manual, I'm still stuck
    I attached a screenshot where I 1) selected a time frame, and 2) hit Cut > Delete.
    How can I get rid of the now-empty time frame so that the video isn't just dark for ten's of seconds?
    Image Attached Images
  6. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Slide the remaining event left, to zero.
    OR
    Use the selection tool to render what you want.
    Also, you can use the up-down arrow keys to zoom the timeline.
    Mar 2011
    Paris, France
    Thanks but still no go.
    I couldn't find how to slide to zero (tried both the flashing grey icon "||" or the yellow arrow above it). Zooming with the up/down arrows, selecting the Selection Edit Tool, and selecting the part I want to remove still leaves the empty section instead of removing it from the video altogether instead of leaving just blank video.
    I expected this to be as straightforward as editing sound in Audacity, but it seems more involved. Maybe I'll find a video on the Net that shows how to do this.
    Thank you.
    Mar 2011
    Paris, France
    Found it: To tell Vegas to move the remaining video to the left, we must enable "Auto-ripple".
    Thanks all.
  9. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    "Auto Ripple" may or may not be desirable sometimes. You can also use the left mouse button.
    Mar 2011
    Paris, France
    Thanks. I didn't understand how to use the mouse to remove the now-empty section.
  11. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    When you mention "AVCHD" specifically, you're referring to a Sony/Panasonic proprietary codec.
    Since Panasonic doesn't make an NLE, Vegas is the best choice for you. Although it is supported in other NLE's too, I'm sure its not supported in WMM.
    Mar 2011
    Paris, France
    Thank you.
    Next, I wanted to export the 40mn, 2.5GB AVC (1440x1080x12, 25fps, PAL) file into something smaller to upload to YouTube, and tried the following two through Project > Render:
    - HDV 720-25p: At 25%, the file was already 1.5GB, so cancelled
    - Program Stream PAL: Went out for a movie, came back: The output is 2GB.
    Is there a way to cut down on the file? A 1h30 movie is around 700MB, so I'm surprised the video I took is so much bigger, although AVC is supposed to already be compressed.
  13. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    720p25 10Mbps
    Mar 2011
    Paris, France
    Thanks. That option doesn't seem listed in Vegas Movie Studio HD 11.0, so I'll try "Windows Media Video > 5 Mbps HD 720-25p", and see how it goes.
    Edit : At 6%, the file is already 97MB long, ie. it should be about 1.6GB once it's done. A 40mn long movie off the Net is about 310MB (90mn, 700MB). I would have expected the WMV file to be on par with that.
  15. Originally Posted by yetanotherlogin View Post
    filesize = bitrate x running time
    Use a bitrate calculator for audio & video if you need a given filesize
    The numbers you are referring to are for low quality SD, not HD
    Resize to SD and use a lower bitrate
    Mar 2011
    Paris, France
    Thanks for the link. The final WMV file is 1GB and WMV seems not to support fastforward/rewind, which makes two reasons to look for something else.
    I'll read up on how to convert an AVCHD file to something lighter for use on the web.
